will a 99-07 chevy fullsize lay frame on 265/35/22
deflaytedwayz2
that the title says. but with out removing wheel wells in front? thanks
Pancho's avatar
Pancho
nope
Pancho's avatar
Pancho
if you do a 265/35/20 you will with alitlle bit of rubbing.......or a 245/30/22 will be very close but still wont.....
deflaytedwayz2
what if the trans crossmember was left stock. it should lay that with out having to remove the wheel wells with a 265/35/22 right?
Pancho's avatar
Pancho
still not enough
granth
just cut em out and put some trailor fenders in....they look better than stock anyways. Let alone, you will PROBABLY (not sure here) have to tub the firewall...
FullSizeRST's avatar
FullSizeRST
245/30/22 i think this is what i have and they still rub in the front it rubbed the inner fender well out .....the plastic
sittinonbagz's avatar
sittinonbagz
to make it lay frame you got to cut out the fenders to make it lay frame mine lays on 265/40/r22 99 silverado i had to cut into the firewall so that the tires dont rub on it hope this helps you here goes some pictures
s10
last post by baha +1y
