flip'n control arms
flip'n control arms
9
94juicednissan
any of you nissan boys ever flipped your control arms, if so how?
9
94juicednissan
anyone?
TwistedMinis's avatar
TwistedMinis
Take it off, put it on the other side, upside down.
dragginmazda86's avatar
dragginmazda86
what is the benefit, i've seen it done on mazda's also?
TwistedMinis
So you don't have to re-angle the arm. On Mazdas I could see it really limiting lift due to the arm design.
hdoggie24's avatar
hdoggie24
i've got a nissan bagged. why do people do this? how's does it work with spindles? any info
get twisted's avatar
get twisted
i flipped and swapped sides with mine just so the ball joints wouldnt bind when laid out but I'm not running spindles so with them there probably not needed unless your running twenty's
MD
mr donut
well since we are on nissans. what about the front stabilizer arms? they run from the lower control arm to a crossmember under the radiator. keep them or loose them? it looks like we should keep them for support.
kaoss's avatar
kaoss
yes keep them. or get tubular control arms, or do what seth did.
unusualfabrication's avatar
unusualfabrication
You need the strut rods on the lowers to keep the tire from smashing into the firewall. If you remove it then there is no triangulation to the lower arms.
