Will I need a notch to lay frame on a 68' c-10 on steelies? It is the coil spring set up in the rear. I don't have the truck yet, so I can't take any measurments.
It really depends on your tire size, and if your Z'ed. To lay on a Z'ed frame you will have to notch in it a little bit. If you just want it to lay level on the front crossmember, all you will need is a mini C notch.
ronnie are you goin to lay it all the way out and so on? i have a complete frt clip that from a 73-87 that will bolt right in that frame so you can run disc in the frt but i know of a guy who builds a complete frt x memeber that lays the truck out on a 29inch tall tire and make the frame lay before the frt x memeber
