Air Ride Suspensions \  SWITCH WIRING????
SWITCH WIRING????
Air Ride Suspensions Q & A
views 536
replies 11
following 5
LndRanger86   +1y
DOES ANYBODY HAVE A DIAGRAM OR CAN EXPLAIN HOW TO WIRE UP A FRONT/BACK/AND ALL UP-DOWN, SWITCHES? I'M GONNA BE UPGRADING TO 6 VALVES AND I'M NOT SURE ON HOW IT SHOULD BE WIRED PROPERLY.I'M JUST GONNA MOUNT THE SWITCHES IN A PANEL ON THE DASH.THANKS FOR ANY HELP OR SUGGESTIONS
acromexicant   +1y
suicidedoors.com used to have a diagram ,check there
acromexicant   +1y
here it is , it also show you how to plumb your 6 vavle setup
http://suicidedoors.com/howto.php
LndRanger86   +1y
thanks. i've never wired up any switchs before so i did'nt know if that would work or not.
LndRanger86   +1y
ok, the s/d diagram dosen't tell me what i want to know.my questions are these.(1) Can you wire switches together; reason being , until i get a switch box i only have font/back.Can i hook the two front fill valves together?wire them into one and run one wire to the front switch?Q (2) when i upgrade to front individual sides and the pancake, how do i hook those wires up to the switch? i have a 6 prong for the pancake, so do i link the two front together into one side of the switch and the back into the other side of the switch?the same for all up too?thanks in advance for any help
LndRanger86   +1y
also my two new valves have 3 wires instead of 2. anybody know why?
maz duh   +1y
One of the new wires on your valves will be an extra ground to hook to the chassis. You can just tie it in with the other ground or leave it unused.
LndRanger86   +1y
thanks. all i've ever delt with are smc's,so there new to me. thanks again
LndRanger86   +1y
BUMP.
cerealkiller   +1y
You're on the right track. Use jumper wires to connect your switches together. You can use the same hot and ground just jump it to your next switch your gonna use.
