Engine Driven Compressors?
scotto79
Its almost time for compressors now, and I saw the Mazdas using the AC compressor. I was wondering which AC compressors bolted up to a carbed 302 and would do the same job? This is all brand new to me and I would really like to learn something about it, thanks.
jsutton's avatar
jsutton
York compressor was on my 77 302. I took it off and did away with all the A/C stuff but I'm gonna put it back on to run the bags when I get to that point. You can probably get the brackets from the junkyard cheap mine is a V-belt set up and has a bracket that the compressor sits on mounted to the front of the head behind the power steering pump and a bracket on top that has the pulley to put tension on the belt. I don't know how the ones with serpentine belts are set up though.
scotto79
thanks Jason
draggin04's avatar
draggin04
a york 210 is what comes on them im putting a 351 in my truck to bolt up
