which bag to run?
befin@ufl.edu's avatar
which bag to run?
olskoolpup's avatar
olskoolpup
I want to do a behind/under axle set up on my sonoma with sleeve bags. I'd like to be able to haul a trailer with it also. i dont think the Firestone F9000s would up to the task of haulin a 18' boat. what other sleeve bag would work, and where could i find them?
olskoolpup's avatar
olskoolpup
bump
lowtaco114's avatar
lowtaco114
why a sleeve bag? why not still use a regular air spring? It'll be able to support towing better that way. Just my opinion.
BioMax's avatar
BioMax
There is a Firestone part developed with Ford for the rear of the Expeditions. Firestone has sence made it into a generic part, I have used it on many different vehicles and have never been dissapointed. I'm not sure the exact part number, but just about any supplier that carries them knows them by 140-95 Tapered bags. If you can't find them, give Randy Davidson a call at AirFlex (951)927-0039.
BTW- Randy is arguably the first guy to have bagged a truck. His first truck was in 1982 and he had a bolt in kit shortly after...
simple-pleasurez's avatar
simple-pleasurez
i would like to see that truck. anyone know of any pics of it
beyond static's avatar
beyond static
what's the size difference in the 140-95 compared to a f9000?
BioMax's avatar
BioMax
The 9000 series part has 110mm(4.3") upper diameter and a 70mm(2.75") lower piston. The 140-95 have a 140mm(5.5") upper and a 95mm(3.74") lower. Also the 140-95 still comes with billet upper and lower mounts, where the 9000 parts are all plastic.
olskoolpup's avatar
olskoolpup
Thanks Max! I figured you may have some insite on this. is this the bag you were referring to?
sd.com has them listed as a firestone 9100. kinda pricey at $195ea, but ill keep lookin around too. thanks again.
olskoolpup's avatar
olskoolpup
howard,
i want to runt he tapered bag b/c im doing a bag over axle setup. the regular double convoluted bag is designed for a 2:1 ratio application where a sleeve bag is designed for a 1:1 ratio. the sleeve will give a better ride and better lift with an over axle setup.
2LOW4U's avatar
2LOW4U
What are some of the downsides to a sleeve bag? I am considering using them on my over axle setup and and trying to determine what would be best.
