fuel pump
jt_haley@yahoo.com's avatar
fuel pump
crzyone1013's avatar
crzyone1013
hey guys, i am about 2 put a cell in my 89 and i was wondering which fuel pump you all use if u can't re use the stock unit. thanks. also is there much of a difference between a 245-35-20 and a 245-30-22 as far as height?
the501clique
my fuel pump is aeromotive tsunami its overkill but it gets the job done. o and msd makes one thats much cheaper and will work good, u just need something that puts out the 38 psi for the fuel injection unless you have the 22r then you can use just about anything. o and the 20s are 26.8" tall and the 22s are 27.8" tall.
truck action's avatar
truck action
I run a Venom pump, puts out a little high than stock!
truck action
smctoy's avatar
smctoy
where did you guys get your fuel pumps from??
lowdyme's avatar
lowdyme
if you call summit racing they have an excellent tech line and if you tell them what your looking for they will help you out and get you the cheapest one that will work
