is the gas neck made of steel?
wileypdf@hotmail.com's avatar
wileypdf's avatar
wileypdf
On the 5th generation honda civics, what kind of metal is the gas tube that goes from the filler hole to the tank.
cuzican's avatar
cuzican
Should be steel.
wileypdf's avatar
wileypdf
that's what I hope but it has a bronze finish like copper or another finish that I can't weld. I want to cut and extend it so to place in a different location. and I don't want to screw up the flow. I'm sure I can use rubber hose too, but just want to know the options
HarryBalls's avatar
HarryBalls
make sure you ground it if your going to relocate it.
wileypdf's avatar
wileypdf
anyone else have any input.
by the way thanks chris
tukn18saccord's avatar
tukn18saccord
i would also like to know
LowOrange88
can you just make a complete new one out of round steel tubing? Stainless would work nice too.
STUD1Y's avatar
STUD1Y
just use exhaust tubing.
make up a template and take it to an exhaust shop..
Wa-la.
wileypdf's avatar
wileypdf
stainless would be sick!!! then I'd need to do the whole aftermarket gas cap like the choppa flush mount style
F
FievalFON
IF YOUR WONDERING IFY OU CAN CUT IT AND WELD THE NECK, THE ANSWER IS YES. IVE COMPLETLY MODIFIED MY FACTORY GAS NECK
