sbc v8 in 94 yota need pics
nichecivic@hotmail.com's avatar
nichecivic's avatar
nichecivic
Hey guys I just bought a 350 chevy to put it in my 94 yota ext cab. It is bagged on 18s. I need some pics to get ideas on how to do this. Will i need to do anything to the oil pan? The only yota i can find like this has the fire wall notched out do i have to do that? I just need info on anything it takes to do this
Thanks
yota93's avatar
yota93
the only one i ve seen is in minitruckin issue march2007 a guy from japan has a 383 in his, and using the stock 5speed trans
scotto79
You would have to notch the firewall a bit just because the distributor sits at the back. It probably wouldn't hurt to get a little better weight distribution moving the motor back a few inches.
nichecivic's avatar
nichecivic
I was just worried about not being able to the distributer if something happens to it. I will be running a automatic 350 tranny to
scotto79
you could use a sheetmetal notch and cut out underneath the cowl, so then just take off the cowl and the dist would come right out.
bowtied's avatar
bowtied
Why not just run a ford 302? I mean don't get me wrong i'm a die hard chevy fan but for ease of tune ups and all the ignition b/s you'd have to screw with a 302 would be a hell of a lot easier in my opinion. Has the front distributor mount. And just as common. Well almost as common as a chevy 350. Just a thought. Good luck.
scotto79
Thats why I went with a 302, and its quite a bit lighter as well.
nichecivic's avatar
nichecivic
Thanks but i am a big chevy guy and i already got a 350 complete from one of my buddies
bowtied's avatar
bowtied
I don't blame you for goen chevy. It's the only way to go in my opinion. Just thought if you could run a for v8 it would be a hell of a lot easier to work on. I just wouldn't want to unbolt the motor just to put a distributor in it or something like that. But either way good luck with it. Should hall balls when it's in there!
treylos's avatar
treylos
Edited: 9/21/2007 10:56:06 PM by treylos
http://www.downeyoff-road.com/
