pressure sensitve shaved door kits?
12 following
SiLveRProJecT
Just wondering what company makes them. You know the one where all you had to do was touch either your door or the window, where ever you wanted to touch. i like the idea of leaving a channel open on my existing alarm system for something else. Any help would be appreciated...
Holeyguy66's avatar
Holeyguy66
autoloc i believe and last i checked they was around 200 to 300 per sensor
N
nvrloenuf
A company called Majic Touch had them like 3 years ago at SEMA.. I want them bad..
And I think they are 300 for the kit, not including the poppers.. But I could be wrong..
cuzican's avatar
cuzican
http://www.lafranceautoworks.com/available-models.php
$399 a sensor and it says they only sell them by the pair at the bottom of the page.
no1lowr's avatar
no1lowr
thats cool
treylos's avatar
treylos
Good luck with them. I personaly helped take them back out of the Overhaulin Magnum cause every time it rained out side the doors would pop open!! So unless they have redesigned some thing i would not bother with them.
jumbo's avatar
jumbo
i also think that would suck if you put it where the handles are, cause it's pretty obvious where the sensor is and anyone could just open your doors.
whynotfab's avatar
whynotfab
What about the "Magna Switch" made by custom classic?
I seen it a while back and was wondering if anyone had used it and searched for reviews but couldn't find many.. but for only $12.99 it'd be pretty cool to try lol. Plus it's a BILLET key
yourbabysdaddy's avatar
yourbabysdaddy
I would personally go with something like the magna switch. You can easilly for only pennies make that same sensor with a home security magnetic window sensor epoxied somewhere hidden on the truck, then glue the 2nd half of the sensor inside your alarm keychain. when you wave the remote in front of the hidden sensor..."POP!"
If you only have one channel left on your alarm, you can get a channel expander from directed electronics. it will make that one channel into 6 extra channels. to activate each channel, you tap your remote button that many times ex. channel 2= 2 presses. chan 6=6 presses.
crazygenius13's avatar
crazygenius13
yeah I like the magnetic one better, I heard about it a long time ago, it at least has some sort of "key" you use with it, even if it is something any Joe Blow could mimic with a magnet or a chunck of metal.
