Mazda Trucks \  a few mazda questions!!
Mazda Trucks Make Specific
views 133
replies 2
SpokaneMazda   +1y
1. my truck idles at 3000 warms up then goes to 2000. whats the deal?2. I put my webber 38dgas on and it also idles at 2000? want to buy it or help3. the check engine light came on? how can i fix it?4. the water temp gauge doesnt work how or what do i need to change? i use a mechanical right now til i can fix the issue
Any help or answers will greatly be appreciated.
"Theres no ride like a low ride" Drag -n- Destroy
oneup   +1y
1. Adjust the idle position screw on the side of the carb or the timing.
2. once again adjust the idle position screw or timing
3. you put a weber on it what do you expect you took off half the emissions bullshit
4. check the temp sending unit on the side of your radiator above the lower hose I believe.
pimp b2200   +1y
Edited: 9/26/2007 1:02:36 PM by pimp b2200
thats for emmissions,when the engine gets up to operating temp that turns on all the emission stuff.the sensor is on the thermostat housing
