Dodge Trucks \  94-01 ram b/d?
94-01 ram b/d?
Dodge Trucks Make Specific
views 285
replies 9
following 6
railinisuzu   +1y
Anybody got one or a pic of one b/d on 24s? I'm gettin the 24s here soon with a 275/30r24 tire they are 24x10 with a + 15 backspace. As soon as I get them we are goin to start cutting to make this big bus lay rockers, no pinch. Hopefully someone hassome pics cuz I'd like to see one. If not then I'd be glad to be one of the first around here at least.
Low_SST   +1y
22s is hard enough, you pretty much loose the hood hinges. You will also need to drop the motor and much as possible to keep it under the top of the wipercowl.
Im starting my 4" sfbf pretty soon now that its all apart.
railinisuzu   +1y
We plan on mating the front clip of a chevy to get a better selection of wheels and hoping it will drop the motor some. If not then we will have to come up with another plan.
NR-Shaw   +1y
you can do 24s and bd it on them but yeh you will have to lower the motor and such i am fixing to do the same and depending on the camber you have you may not have to loose the hood hinges i wont have to but a +15 thats questionable. . . my 24s that i am ordering are 24x10 with a +40 offset . . . i dont meen to bas but i dnt think it can be done on +15s not on a 24x10 at least
Low_SST   +1y
your gonna be pushing it with them 24s unless you get tiny rubber. Im rocking a 285/35/22 gforce-ta with panther realms on mine and bd that shit is gonna be way up there
fyi a chevy clip may not do you any good because you need camber to clear the hump in the fenders, I believe you can switch the rotors to chevy 6 lug tho and get the axle redrilled.
layedouton22z   +1y
i am running a 265-35-r22 in front and they fit by 1/24 of an inch with mad camber check out the total height of the tire and compare....since the front of the dodge is rounded in diffeerent places it is more of a problem...I also did NOT have to lower the motor...just got a different air cleaner and it all fit(changr distributor and wires before you drop...since u will not have much room to do later...)...and chances are you will have ti TRIM the hood hnges(take coil out) I still have stock hinges but that bitch is heavy as hell...hit me up if u need anything...
Low_SST   +1y
Im definately planning on re-engineering the front suspension while its on the frame table. Its gonna get messy trying to stuff those wheels in there
railinisuzu   +1y
I was going to get a chevy clip to get a 24 X 9.5 wheel with a good offset but as I said we will see when it comes apart, just wanted to see one out there.
THE_CRUCK   +1y
265/35zr22 and 275/25zr24 or 255/30zr24 ect... are about the same overall height.
freightdriver   +1y
Edited: 10/9/2007 9:41:12 AM by freightdriver
88 6 lug 3/4t rotors and moser will do your axles if anyones interested...
hey scott any pics of your cab mounts and cowl? any big complications?
