Air Ride Suspensions \  BODYDROP SOONER
BODYDROP SOONER
Air Ride Suspensions Q & A
views 298
replies 19
following 12
killerc10   +1y
HEY GUYS I GOT A QUESTION FOR YALL. SO I'M WANTING TO BODYDROP MY C10 FOR SURE BUT RIGHT NOW ITS ON STOCK RIDE SET UP,I DONT HAVE THE BAG SET UP YET, IS IT POSSIABLE TO DO A BODY DROP WITH THE FRAME ON THE FLOOR ONLY AND WORK AROUND THAT? RIGHT NOW IS A GOOD TIME TO DO IT CAUSE THE TRUCK IS COMPLETELY TORN APART WHICH MAKES IT EASY.AND ALSO CAN I Z IT ALSO.I WANT TO DO IT TRADITIONAL.
olskoolpup   +1y
youll lay rocker just by z-ing the frame and trimming the hump off the bottom of the frame. my buddy did that to his 75 and it lays rocker hard. youll just need to re-make the tranny tunnel.
itll save you some head room for sure. good luck, those trucks look so rad laid flat
killerc10   +1y
YOU GOT ANY PICS? SO HE DIDNT BODY DROP IT JUST DID WHAT YOU SAID?
TUCKINTEMPO   +1y
i did my channel on my silverado while having stock suspension, it made it much easier, crawling under a truck without the worry of it falling on you!
daneisuzu91   +1y
yeah, i have done one on my 70 model chevy pu that i sold.it's the same as any other bd the only difference is that you will be hammered on static drop.
killerc10   +1y
FOR NOW ITS A STATIC DROP BUT THE AIR SHOULD GO IN SOON BUT NOT QUITE YET, SO I JUST WANT TO DO IT SINCE IT SEEMS LIKE A GOOD TIME.ITS NOT LIKE ITS DRIVABLE ANY WAY.
olskoolpup   +1y
patch21 is his profile on here. theres some z pics, none where he cut the bottom of the frame off though.
daneisuzu91   +1y
yeah,it will be cool,at least you will be busy doing something!
daneisuzu91   +1y
I did a 3" bd on my 70 and if I would have z'd the frame it would be a quater of an inch from the door.
killerc10   +1y
YEAH IT JUST SUCKS SEEING IT SO HIGH IN THE AIR WHEN YOU JUST TOOK 2 INCHS OUT OF THE BODY
