Chevy/GMC Trucks \  rear passenger taillight doesnt work, none of it
views 274
replies 10
following 8
pnktco   +1y
reverse, blinker, brake lights dont work on the passenger side, but do on the drivers side. i busted my taillight lense, replaced it and nothing lights up on that side. its a 2005 crew cab silverado. help please.
HarryBalls   +1y
this is a long shot but did you replace the bulbs ???
Blitz Noma   +1y
check the wires, fuse...
pnktco   +1y
i checked the fuse under the hood, its a ten amp and its still good. and do you think that one bulb can mess up all four and cause none of them to light up?
splitdecision   +1y
One light will not keep the other lights from working. Check the fuses in the fuse box on the interior also. It seems like it may be a wiring issue though so check your harness and where it plugs in under the bed. If you buy a new lamp from GM it will also come with a new harness for that side.
STUD1Y   +1y
circuit board failure?
multimeter the plug coming back on the harness. with the tail lights on. go from there.
AiredOut   +1y
Deff a circuit card problem!
Choppin22s   +1y
check the ground wires coming off the lights. maby that could be it. happened to a friend of mine
locaddy   +1y
Ive seen rodents chew through wiring under the bed, check all that out.
pnktco   +1y
figured it out. the reason the one bulb i checked didnt look blown is because the one i was comparing it to was blown. all four bulbs were blown. i guess something shortcircuted all the bulbs when the lense got crakced and messed them all up. whoooops. all bulbs are replaced and working fine now. thanks anyway for the help. iiimmmmmm dumb.
