I have a 91 Mazda B2200 SE-5. The rear was just changed to a Toyota for a 5 lug conversion. Now the Anti-lock light on the dash is always on. Is there a way to eliminate it? I was thinking of grounding the anti-lock harness that was attached to the rear brake line thingy or trying to remove the bulb from the dash. Has anyone run into this before??
big rick
yup
coptic120
Had the same problem with my Caprice so i just removed the bulb. Figured it was from being bagged and on 22's so nothing could fix it anyways and nothing was being harmed.
oneup
I removed all the anti lock bullshit from my rear end then pulled the bulb out of the dash on mine brakes work fine no annoying light worked fine and dandy.
