Bag under axle setups.....
turboh22aakkord
whats up, im probably going to be starting my setup soon on a 93 yota, I was planning on doing just a regular bridge over axle setup with a tri. 4 link, but i was just wondering what the advantages/disadvantages of doing a bag under axle setup? Does anyone have some pics. of their setups? Thanks guys.
LndRanger86's avatar
LndRanger86
WHAT DO YOU MEAN "UNDER AXLE"? MINES BEHIND THE AXLE. IT LIFTS OK W/ 2500'S BUT I'M TRYING TO GET SOME 2600'S.LOOK IN THE SUSPENSION FORUMS. THERE ARE PICS IN THERE.
bowtied's avatar
bowtied
you can do an upside down c notch and then run the bags under the axle. Don't get much lift but it freaks people out when they see it.
turboh22aakkord
sorry for the confusion, I was just talking about the uner axle bag mounts... instead of mounting the bags ontop of the axle with a bracket ... using the under axle bag mounts.
LndRanger86
CHECK MY PROFILE. MINE ARE BEHIND, BUT THEY WORK. I THINK THERE MORE SO YOU CAN HIDE YOUR SETUP AND STILL HAVE SOME FLOOR.TO ANSWER YOUR QUESTION IMO. THE DISADVANTAGE I SEE IS IF YOUR RUNNING BIG WHEELS, YOU WON'T CLEAR THEM VERY WELL.THE ADVANTAGE IS THAT YOU CAN CONCEAL EVERY THING QUITE WELL.
pugz's avatar
pugz
ive got a tri 4 on my dat. and my bags are on the lower bars and pretty much are under the axle. ill get some pics up for you later
turboh22aakkord
Kool man... thanks. PS your Dat. is sweet man.
