are theses any good??
SoTexCustomz@aim.com's avatar
So Tex Customz's avatar
So Tex Customz
i got them the other day from the parker store. also anyone know if they work for copper tubing ?? im only running 180psi
Texmextukin's avatar
Texmextukin
They work good man, I used them for some 1/4" copper line a few times. I haven't had any leaks.
SHOWTIME
that is a push to conect fitting by the looks of it.do not use them on copper they are for synflex aka platic air line and will not work for long.copper fitting are a compression fitting with a tall nut that is tapperes near the line.
simple-pleasurez's avatar
simple-pleasurez
Edited: 9/29/2007 10:15:10 PM by Pootus
not true. you can use ptc connect fittings on regular tubing as well. we use it at work(industrial) all the time with no problems. and our nitrogen is at 250 psi and our air is at 180psi with no problems at allwe use stainless steel tubing.Originally posted by longnlow
pugz's avatar
pugz
ya those will work fine with copper lines.
9
92fordranger
sup man aint tlked to u in ahwile but ya ive used those for coper a few times and for regular line so u should be good
So Tex Customz
thanks guys im going for leak free in 08 haha
dragmatic's avatar
dragmatic
Hmm..."theses". LMAO. Those are good fittings and should work fine for ya.
bdroppeddak's avatar
bdroppeddak
actually those suck, the only parker ptc fittings that are good are the airbrake fittings, they are all brass and dot approved!
