Wheel Questions \  FYI Winter Storage for RT ad Drag tires
Wheel Questions Q & A
views 244
replies 1
following 2
TravisDTD   +1y
Edited: 10/4/2007 9:47:06 AM by TravisDTD
I know this won't apply to everyone but its good info none the less. If any of you are running Track Tires or Drag radials such as the Nitto 555R, the 555RII, Nitto NT01's of similar ultra performance track or RT tires (Falken 615, BFG drags etc.). Nitto Suggest you take them off for the winter if you live in a climate where temperatures drop below 32 degrees. They recommend storing them indoors at a temperature above 32 degrees and at 1/2 the normal running pressure. Drag radials and RT Tires are prone to cracking at freezing temperatures if this occurs have the tire inspected immediately. Attached is a picture of a tire that has cracked due to improper storage at cold temperatures.
no1lowr   +1y
good info
