tacoma clutch master help
1 following
bobjones_jr@hotmail.com's avatar
shideburns's avatar
shideburns
Edited: 10/4/2007 4:10:04 PM by shideburns
ok, truck wouldnt lay on 22's with the stock clutch master so i bought one from an acura legend. at first i had a rubber hose to connect my origional line with the banjo fitting one from the legend but it was bulging when i pushed the pedal, therefor the slave cylinder was not getting all the pressure it needed to disengage the clutch. i fixed the lines and now it still wont completely disengage.
with the truck in gear and clutch pedal all the way down if i give it gas it will take off on me but its very close to disengaging because if i hold the brakes it wont die completly just bog down.
does this make sence? what did i do wrong, bled the lines like 500 times too.
ooops, put in in off topic, how do i change that?
shideburns's avatar
shideburns
any ideas?
