Flipping Tie Rods?
chris03hd@comcast.net's avatar
Flipping Tie Rods?
chris03hd's avatar
chris03hd
My tir rods are snug under the front frame rails when aired out. I can drive this low, so I would like a little gap between them and the frame....
Is it alright to FLIP the tie rod end at the spindle? If so, is it just a simple flip. or is the hole tapered?
22dragn's avatar
22dragn
the hole for the tie rods are tapered. so you have the bottoms redone
MF
Master Fabber
If this is the only thing done you will have major bumpsteer.
mindlissmetalfab's avatar
mindlissmetalfab
Tie rod notches???
jmn444's avatar
jmn444
notch the frame instead or it will bump steer BAD
draggin04's avatar
draggin04
chris03hd's avatar
chris03hd
thanks.. ill notch.
