SHAVING HOOD SQUIRTERS AND EMBLEM HOLES????
thebrantleys3@gmail.com's avatar
LndRanger86's avatar
LndRanger86
WHATS THE BET WAY TO SHAVE MY HOOD ON MY TRUCK? I.V HEARD OF SEVERAL DIFFERENT WAYS BUT I WANT TO KNOW EVERYONES THOUGHTS.I JUST DON.T WANNA SCREW IT UP ANY MORE THAN I HAVE TO IF I CAN HELP IT. THE REST OF THE TRUCK I HAVE UNDER CONTROL BUT I'M WAITING ON THIS. THANKS IN ADVANCE
phillip's avatar
phillip
take your time with some construction paper or use a peice of notbook paper and a crayon laying on its side and make you a template transfer it to metal and cut em out be very carfull welding on the hood if you dont take your time you will cave the hood in remember cover up your windsheild before you even grind or you will ruin it
LndRanger86
thanks.there so small a hole i didn't know if templates would be the best way.
low f350's avatar
low f350
Put a thick block of aluminum or copper (coppers works best) behind the hole and weld on top of it, the weld will only stick to the steel. Take your time and keep the metal cool. Or you can just weld the holes up by building up your welds on top of each other. Its a little harder that way but not impossible.
standardbyker88's avatar
standardbyker88
those two ideas should work. id say any hole over like 1/4", use a brass hammer. and over like an inch, make a template.
low f350's avatar
low f350
Brass works real good to. Forgot about that...
LndRanger86
thanks, guys. i'm hoping to do that this weekend and fix some small damage to the rocker. that for the most part should have my cab squared away
