WHERE TO START
BUD_SELECTS@YAHOO.com's avatar
WHERE TO START
NRlaydtaco's avatar
NRlaydtaco
ok here is my dilema, my truck body dropped, irs, all new box frame cab and front in all on(not tight), bed is sitting on the frame, all frame works is done(paint, chrome, yadda yadda yadda) engine, tranny, driveshaft out of it, where do i go from here, like i dont know where to start to put it back together, still needs body work which can be done off the frame, just lookin for ideas
slammedtoys's avatar
slammedtoys
I would drop in a new motor. get that out of the way.. Supra motor ever crossed your mind?? Get the body work done with it off the frame. My advice is drop the motor in first if you can
NRlaydtaco's avatar
NRlaydtaco
Edited: 10/8/2007 3:27:35 PM by Pdog
MY MOTOR ONLY HAS 7000 MILES ON IT AND PAINTED, AND ALSO HAVE TO SHAVE THE FIREWALL AND FINISH THE TUBS, SO DROP THE MOTOR TRANNY AND DIVELINE IN WITH THE CAB OFF THE TRUCK?
skip1100's avatar
skip1100
yes drop all that in before to set the cab on. It will make your life alot easier
xinsertnamex's avatar
xinsertnamex
probably should have waiting to have EVERYTHING done before painting it.... atleast thats what im doing. Id say cut the well tubs and firewall enough to get the cab on then throw the tubs and everything in just with a few tacks take cab back off and finish off the frame, paint put on runs lines reassemble yada yada
NRlaydtaco's avatar
NRlaydtaco
Tubs are on I just have to clean them up
