Nitrogen setup
Nitrogen setup
blackz151
How mutch psi do you guys have comming out of the regulator....... And can i use smc 1/2 vavles. I have them now i just want to make sure i can use them b4 i go do anything crazy with it
2LOW4U's avatar
2LOW4U
Ya you can use the SMC but I wouldn't open the bottle up to a higher pressure than what the valves are rated at. I only run mine to 200 but I don't try to hop or anything like that.
ShakinPlates's avatar
ShakinPlates
Edited: 10/8/2007 8:07:18 PM by ShakinPlates
unless you want to hop, even 175 is plenty and pretty fast. depends on how much wieght you have to lift up and if you are running shocks too. i have a 90 fullsize without shocks on air cutoff on 175 and i can get the entire back end off the ground...
BTW the size of the valve doesnt relly matter if you arent trying to hop. 1/2 actually can run a pretty quick setup.i know people who run the bottle on 3/8's so it just depends on the quickness... just my .02
railinisuzu's avatar
railinisuzu
I usually run mine at 200 but I heard that SMCs are only rated at i believe 150. I used the GC 450s for 5 years and never had a problem!!! dam good valve! i.m.o
snydecat's avatar
snydecat
i have blitzluft valves and i would run like 120 to 150 and i could get the front end off the ground like an inch or two. it made me a little tense when i would drag of the high way cause id have to lift the rear and it would come off about 6 inches. so i got the fill controls that helps ALOT. haha. but it depends what yer puttin in on my yota barely needed any pressure. oh and i also turned it up to 450-500 and hoped it like two feet in the air. so id just kinda play with it a little and see what ya like.
