Air Ride Suspensions \  How much should I expect?
Air Ride Suspensions Q & A
views 149
replies 6
following 5
granth   +1y
Edited: 10/9/2007 2:07:19 PM by 72bumpside
I want to get a front clip done on my f100, but I want it narrowed as well. So I can turn low. Looking to run a chevy clip, but HAVE to keep the the 3 speed, which means the stock column, I can't change it. So, probably just use like a johnny joint on the steering column to the box.
Another thing is, my frame only sits like an inch lower than my rockers, so I want to just cut that part off the bottom of the frame, it's not the whole length. Get it plated and all, so I can lay rocker when all is done. All on 30 inch tires. The rear will be done, just want the front and frame cutting done. How much to get it to the point of wiring should I be looking for?
2500-3000?
Oh yah, bag work done, but no parts other than bags, fitting and enough line to throw a shraeder on the front to lift it to roll around.
olskoolpup   +1y
are you supplying the clip?
id say 2500-3000 is about right for baggin, narrowing and trimming the frame. most of the cost is going to be due to narrowing all the steering and keeping your stock column.
granth   +1y
I could if it would help yah, figured a shop may be able to work with a junkyard more than a single person.
one_low_sixty8   +1y
where are you located at?
TwistedMinis   +1y
A Johnny joint isn't going to do anything for your steering.
I think you're looking for a universal steering joint.
granth   +1y
called it the wrong thing, oops. I meant the extender/joints people use.Universal steering joint I guess is what it is called.
Either way, any clue about what it would cost in south east? I may be able to get away with an s10 clip...
bodydropped85   +1y
an s10 clip will work just as good as a camaro instead of narrowing a wider one. 3g is a lil on the cheap side for all that work, but hell id prob do it at my house for that lol.
