225x40x18 Tire/rim
gkellison46@gmail.com's avatar
225x40x18 Tire/rim
truck action's avatar
truck action
Will be starting the front end work today, front is tubed at wheel well ,not at firewall, looks pretty tight now at ride height of 4". What problems if any can I watch out for?Have new trans mount,a-arms,ect. Will I have to grind all the pinch away at the wheel well?Any one running this size tire/rim, please advise!
slammedtoys's avatar
slammedtoys
I did grind mine away because of the rubbing issue. also you may want to look into pounding in the inner fender to allow you to turn fully with out rubbing
truck action
Edited: 10/11/2007 10:37:02 AM by truck action
Inner fenders have been replaced with tubs!!Can see where the tire has been rubbing already. What is your tire size? My truck is a 88
slammedtoys
well i am running a 17 inch rim with a 245/40/17 so my specs are close to being the same as yours. plus i have a positive offset to make them tuckk more
