viair ?
tad99@aol.com's avatar
viair ?
ptman2002's avatar
ptman2002
i am taking out my 2 viair 400s and putting in 2 viair 480s. will it be a simple exchange or should i change relays or will there be and problems? any help is appreciated.
slammedtoys's avatar
slammedtoys
are you selling your 400s?
skip1100's avatar
skip1100
just un plug the old, and plug in the new.
1lownismo's avatar
1lownismo
If you buy the dual pack it comes with new relays also. and pressure switch as the 480s are 200psi if you need some ill hook you up special this month....335 for chrome 325 for pewter
ptman2002's avatar
ptman2002
yeah i have the dual pack. the relay i have is holding the 400s, just didnt know if it would the 480s as well. also have a 60 amp fuse on them. i have the pressure switch but i dont run one, just use a toggle on them. thanks for the info. as for the 400s they will get used on something else. i also have 2 thomas 327s. just dont know what they are worth, so dont know what to sell them for.
get twisted's avatar
get twisted
Originally posted by ptman2002
i have the pressure switch but i don't run one, just use a toggle on them.
please do use a favor and run a pressure switch its only a ten minute thing to put on your tank you forget to shut it off and aver fill your tank and have shrapnel going everywhere or you blow out a bag and roll you pt on the highway and take out three cars and kill them also you can run the toggle to the press. switch and it would be the same as you have it know just safe im not trying to be a dick or talking shit but damn you have all the parts already
slammedtoys
yeah i have the dual pack. the relay i have is holding the 400s, just didnt know if it would the 480s as well. also have a 60 amp fuse on them. i have the pressure switch but i dont run one, just use a toggle on them. thanks for the info. as for the 400s they will get used on something else. i also have 2 thomas 327s. just dont know what they are worth, so dont know what to sell them for.I dont know what they go for either. So i guess we are at a stand off!!!! I may want them though. I dont know if Viair is going to be able to rebuild my 450
ptman2002's avatar
ptman2002
well all my stuff is ran through the switch, so nothing works unless the key is on. even if i leave the toggle switch on if i cut the car off it wont continue to run.
soccorjimmy's avatar
soccorjimmy
Will the same work if I go from 380's to the 480's? JIMMY
skip1100's avatar
skip1100
yes
