Edited: 10/14/2007 9:07:54 PM by R0CKSTAR
What do you think my Silverado is worth? Im probably going to sell my truck. Its got everything done to it. Needs a little TLC on the paint and the bed is gutted.
Its a 1994 with a v6. About 140,000 miles but runs good now. I think it has a newish water pump and some other stuff. Ill have to look at the receipts again. Tires still got tread except it has some cuts from rubbing.
Since Ive had it Ive re-plumbed the air suspension, re-did the electrical from the battery to the engine, replaced all 4 shocks, and put in 2 viar 480 comps. All done at GO-EZ Customs except for the electrical.
Only mechanical problems is that it has a bent rear axle but you can get a new one at a junk yard for like no more than $200. Its still drivable but I think my mom said the back drivers side tire wiggles a little when you go over 60mph. And I think there is a leak from the tank to the front passenger side bag because over a period of time it will start to lift.
pics and other specs here
http://www.streetsourcemag.com/ViewOwnerProfile.aspx?ProfileID=47180
