turbo motor
turbo motor
Railin22
I have the stock 2.2 in my 88 mazda, and I was just wonder if any one knows of any way that I can turbo my truck and keep it carbed. I have a weber now. I can get the stock turbo and exhaust manifold off of a mx6 which I have access to. I would like to do just a blow through carb but I don't know if anyone even makes one for our trucks.
dssur's avatar
dssur
no one makes ANY turbo kits for our trucks. Blow through, draw through, EFI or otherwise.
You would have to use a draw through unless you modified the carb to be pressurized. A draw through system mounts the carb to the inlet of the turbo.
The problem with carbed turbo engines is the drivability. Since you can only essentailly tune a carb for a specific powerband, and not a range of driving, changing the fuel requirements by bolting on a turbo will make you tune it for maximum power, which hurts drivability, or for drivability, which hurts power.
Additionally, using a draw through setup is only really useful at low boost pressures. Same with a blow through, but for different reasons.
I guess what I am saying is, that everything worth doing is hard. Either convert it to EFI, or cobble together a carb'd turbo. There will be lots of people who will oversimplify and say you can add a turbo to anything, but in implementation things will get cloudy and they will disappear.
jealousonezenvy's avatar
jealousonezenvy
89-91 ford probe turbo engine will swap into it
