ViAir Rebuild ?
BaggedMazda87@yahoo.com's avatar
ViAir Rebuild ?
BaggedMazda87's avatar
BaggedMazda87
380C
Any sweet tricks to pulling the counterweight(i guess you could call it a "crank" ha) off the main motor shaft?
I got the set screw out but the motherfucker is seriously stubborn.
If nothing else i can just cut it off. I just wanted to check to see if there was anything special that helped GET IT OFF
Word
BaggedMazda87
Anyone?
IB2LOUD's avatar
IB2LOUD
can you fit a small flat head in the crease where it goes over the shaft?
i've never looked in a viair, just the DC7000, so it may be different
BaggedMazda87
Yeah I can. I've done that with one on each sde and twisted them both REAL hard and it still won't break loose...
I've tapped it with a hammer around the whole counterweight, pry'd at it, yelled at it a little...I think I tried it all except cutting it off...
TwistedPhil's avatar
TwistedPhil
Try heating up the counterweight with a propane torch to get it to expand- i think they're heat pressed on from the factory, so that might work. Good luck!
-Phil at FBI
I
IMDORED
3 JAW PULLER?
BaggedMazda87
I just cut the fucker off
haha
Worked like a charm
Thanks Phill, that probably would have been a better idea!
And holy shit the piston seal is SO much bigger than the cylinder bore, wow, that was loads of fun lemme tell ya
...actually wasn't that bad...
s10
last post by baha +1y
