type L cooper air lines
patrickspaintshop@yahoo.com's avatar
68ledsled's avatar
68ledsled
wondering if any body had used type L cooper line before and how well it held up. I was told that if you tried to make bends in it would crack
dragggn's avatar
dragggn
I have been told both story.. its great and it will crack under vibration...???? if you figure it out lemmy know!
marcus760
dont use it.it does crack and the vibration will cause leak after leak,my friend used on his c-10 and it wasa pain in the ace from beging to end
fatheadjames's avatar
fatheadjames
Had it on my truck for about 2 maybe 3 years and never had a problem.
nryota's avatar
nryota
amen brother... always used copper airline since clyde from silverstar told me about it 5 or 6 years ago. never had a single prob. no cracks (actually never even heard of this) no leaks when run into the fitting straight, never had a blown line, you can run it right next to the exhuast no prob. and you can even make cool designs with it. lol
eks10BDRG-N's avatar
eks10BDRG-N
Edited: 10/23/2007 7:39:54 PM by eks10BDRG-N
type l copper here for about 3 years and no problems. get a good quality bender and you have no issues bending it. heres what my bender looks like
balcar's avatar
balcar
From what I've heard and can visualize, i would assume it cracks on truck with lots of frame twist, c10, older F150, etc. More rigid frames should be fine (in theory).
My question is what fittings do people use? I've tried it with a few PTC and have yet to get it to be air tight..
disfiguredS10's avatar
disfiguredS10
If you buy it in a roll it will bend, if it comes straight it will crack when you try to bend it.
fatheadjames
I had legris ptc fittings on mine and worked great.
eks10BDRG-N
used the fittings ekmw sells. used the copper that was in a roll. no issues with leaks or with bending.
s10
last post by baha +1y
