Mini Truckin General \  help! mustang ll dimensions
views 125
replies 5
built to drag   +1y
does any one have them?
built to drag   +1y
bump
LOW99GMC   +1y
I've got some for you! Let me know what you want to put it on and your track width,(Center line to Center line of your front end), and I'll get you some numbers!
built to drag   +1y
cool thanks. the front end is going on a 1932 chevy sedan. i dont have a track width yet but i will by tomorrow. i guess i will just use the same width as the factory
LOW99GMC   +1y
You will need to start with the track width and wheel size to determine where and how high the you crossmember will need to be. If you are using aftermarket control arms and spindals, you will need those for mock up. Will you be making your own crossmember?
maz duh   +1y
You can e-mail Paul at welderseries.com. He has decades of experience with the M2 suspension and is very helpful. Hios company offers laser cut weld it yourself M2 front crossmembers and laser cut brackets designed for DIY street rodders. Check it out.
