RUSS-D got a question mazda god
jeffreyryanmotes@gmail.com's avatar
cookiemonster13's avatar
cookiemonster13
hey man i got my 91 back on the road. i put a water pump, a head gasket, and a timing belt in it. i got it back together fired right up but now when you give it gas it has a hesitation then it takes. it is like dead pedal then instant power. it drives fine it just has a dead spot in the throttle. got any idea? it is not timing so i assume something in gas delivery???
lowazzmaz
my mazda did that and it was a carb issue changed to a webber and all was good.
cookiemonster13
this one is fuel injected
cookiemonster13
one more thing russ, how do you adjust the idle on the FI trucks?
dssur's avatar
dssur
sounds like the throttle position switch on the throttle body.
you can only set base idle on the EFI trucks, then the computer fights any changes.
cookiemonster13
one more thing, the check engine light comes on only when i am idling and as soon as you touch the throttle pedal it goes off instantly. ot any ideas
2ManyProjects's avatar
2ManyProjects
did you double check the timing marks be a 1/2 tooth or tooth off will give you hesitaion when you first hit the gas.
