Ask A Pro \  abcdefg...
abcdefg...
Ask A Pro Q & A
views 1218
replies 10
following 11
4twnty   +1y
Over the last decade or so air suspension has become extremely popular in the custom automobile culture: street rods, trucks, cars, and even motorcycles may have air springs. They are used in these applications to provide an adjustable suspension which allows vehicles to sit extremely low, yet be able rise to a level high enough to maneuver over obstacles and inconsistencies in the roadways (and parking lots). These systems generally employ small, electric or engine-driven air compressors which sometimes fill an on-board air receiver tank which stores compressed air for use in the future without delay. High-pressured industrial gas bottles (such as nitrogen or carbon dioxide tanks used to store shielding gases for welding) are sometimes used in more radical air suspension setups. Either of these reservoir systems may be fully adjustable, being able to adjust each wheel's air pressure individually. This allows the user to tilt the vehicle side to side, front to back, in some instances "hit a 3-wheel" (contort the vehicle so one wheel lifts up from the ground) or even "hop" the entire vehicle into the air. When a pressure reservoir is present, the flow of air or gas is commonly controlled with pneumatic solenoid valves. This allows the user to make adjustments by simply pressing a momentary-contact electric button or switch.
The installation and configuration of these systems varies for different makes and models but the underlying principle remains the same. The metal spring (coil or leaf) is removed, and an air bag, also referred to as an air spring, is inserted or fabricated to fit in the place of the factory spring. When air pressure is supplied to the air bag, the suspension can be adjusted either up or down (lifted or lowered).
For vehicles with leaf spring suspension such as pickup trucks, the leaf spring is sometimes eliminated and replaced with a multiple-bar linkage. These bars are typically in a trailing arm configuration and the air spring may be situated vertically between a link bar or the axle housing and a point on the vehicle's frame. In other cases, the air bag is situated on the opposite side of the axle from the main link bars on a additional cantilever member. If the main linkage bars are oriented parallel to the longitudinal (driving) axis of the car, the axle housing may be constrained laterally with either a panhard bar or watts linkage. In some cases, two of the link bars may be combined into a triangular shape which effectively constrains the vehicles axle laterally.
Oftentimes, owners may desire to lower their vehicle to such an extent that they must cut away portions of their frame for more clearance. A reinforcement member commonly referred to as a C-notch is then bolted or welded to the vehicle frame in order to maintain structural integrity. Specifically on pickup trucks, this process is termed "notching" due to the fact that a portion (notch) of the cargo bed may also be removed, along with the wheel wells, to provide maximum axle clearance. For some, it is desirable to have the vehicle so low that the frame rests on the ground when the air bags are fully deflated.
TwistedMinis   +1y
Why is this in the Ask Max section? Its not even a question.
purplekush   +1y
if thats a question its a verry long run on sentence
but i think its just his 2 cents on air suspension for people who dont realy know about it?
aon-teach   +1y
Maybe he wants his own section called ask 420 and this is his proof that he knows whats up? Or maybe not.
twistedsdime   +1y
Congrats on learning how to use copy paste. Now were you trying to ask max a question or just being obnoxious?
snicker2938   +1y
what the f--k is the point of that?
granth   +1y
sooo.......who wants to explain why people REALLY put air suspension on?
BioMax   +1y
AVTekk   +1y
.com?
no1lowr   +1y
tuesday!
