Toyota Trucks \  22re wont run right
22re wont run right
Toyota Trucks Make Specific
views 137
replies 6
following 5
doordraggintaco   +1y
has been running fine until tonight.it acted like it ran out of gas earlier (gas hand dosnt work) so i waited on someone to bring gas,fired right up after 20 or so minutes,ran fine to get me home,now i go to leave again and it will barely run.thinking fuel pump goin out or dirty fuel filter.anyone have this happen before?or have any ideas of what the problem is.thanks in advance
datsunlayingdoors   +1y
how many miles are on the truck?? my toy did this once before when the timing chain took a crap on me.. or it could simply be the fuel filter but that thing is a bitch to change if i member correctly
smctoy   +1y
Sounds like when you ran out of gas the pump
sucked up some trash. Id check the filter closest to the tank & see if that makes a difference!
impala_631   +1y
hook up a fuel pressure gauge so you know for shure that its a fuel problem, then check filters then your pump
nryota   +1y
just sell it and buy a new truck...
doordraggintaco   +1y
found the problem.had a leaking water line from the engine.the intake elbow was dry rotted a little and letting water into the intake.all fixxed now.was a new one on me.wont be sellin this one.
smctoy   +1y
glad to hear that you got it fixed!
