pinion angle on s10 link brs
minitruck_madness
I am too cheap to buy a 2 link plus i wanna build my own anyway,but i cant figure out what the pinion angle should be on the block i put on the 2x2 tubing i made the link bar out of- any help will be appreciated
mindlissmetalfab's avatar
mindlissmetalfab
huh?
Texmextukin's avatar
Texmextukin
Just use the same angle thats on a 4" drop block.
TwistedMinis's avatar
TwistedMinis
Your block doesn't have a pinion angle. Only your pinion has a pinion angle.
domepiece
Just cut your stock spring perched off and go buy some new ones. MOPAR has sets for $8. Put them on where they need to be and bolt it down. Run the suspension through its movement and make sure nothing binds up. Once your happy and it doesn't bind any more, weld the mounts to the axle.
