93 toyota handling!
93 toyota handling!
1987bseiresman
i have a 1993 toyota 2wd truck.it has a djm drop kit.and it's lowered 1 inch on cranked torsions.it 14 inch wheels on 60 seies tires. iwas woundering how to make it handle better. i'm thinking 18 wheels and tires with a 40 oe 35 series tread. also i was thinking of upgrading my swaybars and bushings. by the way what would be a proper offset so my tires and wheels don't rub. any help would be cool.
skip1100's avatar
skip1100
get a rear sway bar. bottom line its a truck and its not going to handle like a sports car without ALOT of mods
BioMax's avatar
BioMax
A rear swaybar is not the way to a good handling truck. Your best bet would be to spend a couple of dollars on good shocks and replacing all of your stock rubber bushings with eurethane. With a little bit of work, you can have a very nice handling truck. Now if you are trying to do this with an air set up you will have a lot more problems on your hands. If it's that important to handle well and you are on a budget, don't bag it.
skip1100's avatar
skip1100
It sure helps tho
