Mazda Trucks \  will my front lay if?
Mazda Trucks Make Specific
views 310
replies 14
following 12
jealousonezenvy   +1y
im relocating the front shocks, removing torsions, cutting bumpstop mounts off
93mazdawg   +1y
you will have to cut out some of the inner fender and remove the sway bar
jealousonezenvy   +1y
will it drive like shit without the sway bar?
framedragger   +1y
flip the ball joints
trashed   +1y
you have to notch the lower control arms before it will lay out.
framedragger   +1y
actually you may not have to notch the control arms.it depends on what size wheel you run and if you make a spacer when you flip the balljoints
TwistedMinis   +1y
I don't like the idea of spacing the balljoints. Flipping them is about as far as I would go.
It won't ride like shit without a sway bar, as long as you have two valves per bag.
trashed   +1y
im saying without flipping the balljoints it wont lay no matter what size wheel you have, unless you notch the control arm. i believe you can get up to an 18 without having to flip the BJ's.
TwistedMinis   +1y
Flipping them is a good idea though, because it keeps the lower arm about 3/4" lower than it would with them in the stock location. The LCA sitting lower, helps keep the upper bag mount lower, which will give you maybe an extra 3/4" of lift. The way the Mazda arms are made you need the bag mount as low as possible.
jealousonezenvy   +1y
thanks for all the info..i dont know yet to keep the sway bar or not. im wanting 20'' wheels bad
