Chevy/GMC Trucks \  s-10-blazer disc brake conversion
views 162
replies 4
cheeks Sunset SD   +1y
I have an 02' s-10 I want to use the blazer axel's with the disc brakes do I just get the same year or is there something special I need to look for?
yeah it's 2wd I just need help stopping the 22's. But it is pretty much swap one for the other right?
xinsertnamex   +1y
You dont need the axles just the backing plates calipers and caliper brackets
AVTekk   +1y
thats right, you dont need the whole axle, but if you can get one cheap then go for it. there are differences on the spring perches but you can cut them off.
chillnlikavilln   +1y
one thing that i have seen is that the caliper sticks inboard a bit more,mostly the top bolt,and will hit the frame when the truck is twisted like going up a drive way. just make sure no bags orother items are in the way .just a lil fyi
