Toyota Trucks \  Need Ideas for bagging.
Toyota Trucks Make Specific
views 136
replies 9
following 6
69cdime   +1y
Edited: 10/29/2007 12:58:17 PM by doberman6220
I have a 92 yota to bag after I install the lexus motor. I plan on removing the inner fenders completely. So I have the clearence. Where should I start with the bags? I definately want the full set up, front,back side, side and all that. I just need pics with detail that I can get ideas from, not to copy. More pics the better. Thanx.
skip1100   +1y
here is a picture of my front bag setup. sorry the picture is kinda bad but its all i got
69cdime   +1y
is that all bolted on?
TwistedMinis   +1y
The bag mounts must be welded on.
skip1100   +1y
I dont know what you think is bolted on. The bag mounts are all welded as you can see in the picture.
69cdime   +1y
Ya I see the welds. What bags are you using?
Yoter   +1y
Well personally when I do my set up this winter I plan to get do all the wiring for the compressors and the switch box first and ounce that is done and everything is working perfectly. I will move onto doing the front and then back because the back is going to take the most work. Just a thought because it seems like the most problems with air ride lie in getting the compressor's and boxes wired correctly and getting everything air tight. and the rest is just getting everything fabbed up buy someone that knows how to weld good. Planning ahead is always essential. Just my two cents hope it helps
Have any ideas for the what you are going to do for the rear set up ?
skip1100   +1y
Im running Slam re7s up frontOriginally posted by Yoter
Have any ideas for the what you are going to do for the rear set up ?thats going to make things twice as hard! because your going to have to work around all your air line and weld next to it. It wont be a very clean install either because you change alot of things when you get into the thick of it. and plus you cant make sure everything is air tight until you have all your bags mounted. link the rear and bag the front and then move on to wiring it all up.
krayla   +1y
Go to yotascene if you need a lot of info. I did mine all this year. front first and then the back twice lol. dont 2 link thats for sure even if it is just temporary.
69cdime   +1y
I went to yotascene.com and characters. Pretty sweet!!! Does anyone know anything about street scraper set ups, are they any good?
