primer and rain
primer and rain
yasmany454ss avatar
yasmany454ss
sup guys.here is the deal it has been rainin here for a couple of days i have my truck under a carport and covered with a tarp but the left side gets wet a lil.im in the process of sanding it my concern is that if that will affect the primer and then cause ploblems after paint?i put epoxy over bare metal and body filler then filler primer. i hope everything makes sence thanks
locaddy avatar
locaddy
Should be fine just try to set it out in the sun for a while after the rain stops to try to dry it out. The filler primer sponges up the water but if the sun evaporates it all out you shouldnt have any problems with your paint.
Buckysheezy avatar
Buckysheezy
Yea... i have heard of people leaving it in the sun for 3 or 4 days before painting
yasmany454ss avatar
yasmany454ss
if not like is getting pooring rain is just a lil bit.. so i guess is no ploblem
granth avatar
granth
well i would have thrown a sealer coat over the body work and then used that as the primer coat, but atleast it wont reach the bare metal.
you should be fine, your going to take most of that primer down anyways.
chevyman992002 avatar
chevyman992002
the epoxy will do a pretty good job of protecting the metal. you should be fine.
ilovebeer avatar
ilovebeer
shouldnt be a problem just make sure you sand the surface rust off if any and use some metal treatment and clean the shit out of it! good luck!
