question about bagging the front of my toyota
superhotsancho@yahoo.com's avatar
waynehammer's avatar
waynehammer
ok here it goes, i have a 94 toyoa pickup and im gonna bag the front in the next couple days.. will it lay frame without raising the condrol arms or will it be higer in the front.. if i dont have to raise the arms im not going too..
thanks for any help..
FLYINLO's avatar
FLYINLO
You will need to Z the frame at the firewall to mak it lay flat.
waynehammer
how many inches
FLYINLO's avatar
FLYINLO
Don't remember exactly.....just get the truck laid out on the front crossmember, then tack on some steel supports to hold the front of the frame in place directly ahead of where you want to cut. You will want to make your cut close to the firewall straight down 90 degrees to the floor. when you get your cuts made the rest of the frame should lay ( assuming you have already addressed the tranny crossmember) and still be butted directly to the front clip, only a little lower. Tack it in place and measure how much it dropped and write it down, Then weld it up, gusset and plate. Then take the measurement and cut the front frame horns directly behind the core support where the radiator sits and move it down an equal amount before welding, gussets and plating. You will probably have to move the motor down a little or cut a little on the hood supports when you are done in order to close stock hood if you are bodydropped.
TwistedMinis's avatar
TwistedMinis
If your front cross member has not been drug yet, its about 1.50". Bout you can cut about .50" off the bottom if you want to.
BAGGEDTACO45
hey you dont need to z the frame to bag the front all thats gona happen is ur frame wont lay flat in the front
waynehammer
well its not body dropped yet but im dooring it soon but of coarse i want it to lay nice and flat first..
waynehammer
as soon as i bag the front and get it nice and flat im gonna start the body drop . i want to door it but i might just go to the rocker because of the headroom... i forgot to mention im chopping it 2 inches
skip1100's avatar
skip1100
you should stock floor it while your doing your Z. knock out 2 birds with one stone, and then you dont have to worry about head room.
waynehammer
is yours stock floored and traditional?
