dilema
jt_haley@yahoo.com's avatar
dilema
crzyone1013's avatar
crzyone1013
hey guys i have a dilema on my hands. my ruck is going under for a full frame redo. my problem is which direction i should take it. the current plan is to stock floor it to the rocker on 20's up front and 22's in the rear. but how close could i get to pinch on 22's up front without going through my hood? probably won't go that route if its not very close. i saw a yota on here w/ 22's but i haven't gotten any response from him. i also saw the older yota on here with 22's close to the pinch. i am also thinking about staying on my 20's with the 225-35-20 tires but to the rocker how close will i be to the hood? if there is any room i will go until there is none. pretty much i want to go as low as possible with at least 20's. in the back i don't object to a small amount of tread above the bed as long as there is no rim showing. i would like to go almost to the door but i would have to go down to 18's with that, right? with 19's i would think about it. damn it sucks to be indecisive at the last moment. but if i do not change any plans it will proceed with a stock floor to the rocker on 20's and 22's. do any of you guys have a suggestion for the truck? it is still going to be a daily and i am not concerned with tire prices so that will not affect my decision. i also want proportion, to an extent. later this summer it will go back under for a 3" chop. if any of you all can make sense of my ramblings and help me out i would appreciate it. by the way, i still have my taco i am trying to get rid of.
TwistedMinis's avatar
TwistedMinis
If you really want 22s, you'll find a way to make it work.
skip1100's avatar
skip1100
ya make the 22s fit! I only issue i see you running into is getting enough lift to drive it around everyday. and if you go to the doors you can only fit 17s. I have a 1/4'' rocker on 18s and my tires hit my fenders. so if your going to 20s or 22s stick with laying rocker or pinch.
