frame jigs?
begfomurrcy@yahoo.com's avatar
frame jigs?
suckafree's avatar
suckafree
just curious how people are going about building frame jigs on trucks with frames that need to be z'd? looking for the best way to do it so it all stays square and will lay out right.
onehot69stepside's avatar
onehot69stepside
Edited: 11/10/2007 12:01:05 AM by onehot69stepside
people pretty much do it on a table.
Once they get the frame all plum and square with the table, they weld bar stock to the table and frame horns for the front side that stays the same and then do the same for the back part that stays the same. Then make your cuts perpendicular (square) to the table.
Then raise the center section however much you are doing then weld her up. Get it fully reinforced and welded before cutting the bar stock away from the frame.
Ive seen people use all thread for the center section as well to keep the center section in the right spot but "adjustable".
CC
creative concepts
if you're talking about doing a frame that has to be z'ed to lay. What I do is get it square, tack my holders into place from the firewall back, then up front, i will stick taller holders and mark on there where X amount of inches up are.. cut the front end, get it held into place with spacers, then tack it to the holders.. then filler the cut area with gussets.
WF
Wicked Fantacies
Yeah you don't need a whole table just get it level and weld some cross supports so nothing gets crooked and measure measure measure then cut and weld.
slammedxonair's avatar
slammedxonair
i would like to see pics of other frame jigs also, as i will be buildiing mine for my shop this week, i know theres a thread about it somewhere but i cant find it and the search wont work for me.
suckafree's avatar
suckafree
yeah kinda what I was thinking, level off the frame or do a half ass "z" on the stock frame(seeings how I wouldnt be using that part of the frame anyway) to get the measurements right on the body mounts.
