Dodge Trucks \  removing back window
Dodge Trucks Make Specific
views 311
replies 5
following 5
Jance Customs   +1y
I have a 2000 Dodge Ram that has a sliding back glass and I want to replace it with a solid back glass that I have on another truck.
How hard is it to remove the back window? Is there any special tools that I need to use? It has a few tabs and then it is sealed with silicon. I talked to the local glass shop about doing it but they couldn't guarentee they wouldnt break it.
Any ideas? Thanks!
BIG J   +1y
I had a couple of glass shop say the same thing when they did mine. Every thing worked out for me though
crewcabondubs   +1y
do not use regular silicon cause it will eventually rust out the metal around it or so im told. you have to use a urethane(sp?) type sealer
Dejavu   +1y
yea i work for safelite autoglass... dont use regular silicone... it will corrode your pinchweld... we use a special eurethane to hold it in... the dodge truck backglass in my opinion is a pain in the ass most of the time... you have to consider my enviroment.. i work with broken glass so basically i get to rip the glass out and cut it out however i need to and its still a pain... its gunna be a chore for you to attempt it yourself for sure.... i would recomend getting a class company to do it. .. oooooooooooooooorrrr come over for some dinner, bring some beer and im sure i can get it out!
roadstar   +1y
It's not bad, just takes time. The easy way is to remove the headliner & the trim on the sides. Go to a parts store and buy a cold knife around $8.00 it should come with a blade 3/4inch. Then go to a auto glass shop for a 1.50inch blade.Just cut from inside you can do it .Call if you need more info Jeremy (405)-6401289
Jance Customs   +1y
Thanks for the info! I talked to the local glass shop again and they basically told me everything that was said already. They said I could borrow the tools and anything that I need to do it myself. Both trucks have easy access to the back window so I hope it will work out.
Just to be on the safe side. Does anyone know for a fact if you can swap the 94 back window with a 2000 model? The only real difference I see is the outside molding other than that it "should" fit. Just thought I would check
Thanks!
