Air Ride Suspensions \  valve slow down question
Air Ride Suspensions Q & A
views 1239
replies 4
following 5
Slappy Mc Nasty   +1y
i have 3/4" fill valves and 3/4" line and this shits jus fast, i bought the valves awhile ago and now im kinda wanting alittle slower fill. can i/what if i got sum 1/4" air line and added it between the valves and the bags,. would this slow the fill speed? i understand the valves are still 3/4" and 3/4" pressure will still release from the valve when the switch is hit, but having 1/4" line should (i.m.o.) slow it a tad.............. pros/cons gurus????
ShakinPlates   +1y
Edited: 11/16/2007 12:27:02 PM by ShakinPlates
heres your answer my dear friend slappy...http://www.suicidedoors.com/AirManagementValveFillControls.phpjust use a 3/4 to 1/2 fitting and your done!
Actually try kris at AVS first but im pretty sure they dont have these.
scotto79   +1y
you could use those or just add an inline flow control.
cookiemonster13   +1y
ball valve between the bag and valve and for dump screw a 3/4 inch plug in with a small hole drilled in it. take it out and redrill the hole until you get the speed you want.
DRAGTHIS   +1y
just lower the pressure for ur up.. and put a 3/4 to 1/4" reducer in ur dumbs..
