ball joint
doordraggin@yahoo.com's avatar
ball joint
rizz0's avatar
rizz0
search doesnt work or i wouldnt be asking this cause its been covered a million times but whats the part number to the lower control arm ball joints that fit a toyota spindle. i know seth has to know. and also does anyone know a part number to a press on lower rather than a screw in type?????
rizz0's avatar
rizz0
bump
TwistedMinis's avatar
TwistedMinis
The lower screw in balljoint is Moog K727.
rizz0's avatar
rizz0
does anyone know of a press in joint???
TwistedMinis
If you find a balljoint that says it will fit a Mustang II spindle, that is press in, it will work.
e10pvmt's avatar
e10pvmt
ok so i ordered this ball joint
http://www.speedwaymotors.com/p/3523,27_Screw-In-Lower-Ball-Joints.html?itemNo=ball%20joint
and it doesn't work...the castle nut wont spin its too big and the actual shaft is too fat and wont go in far enough for the cotter pin to go in if the castle nut did tighten down...it says ref moog K727...is there somethin i am missin??...Do i need to get these replaced or do i need to rheme out the hole?
loasian's avatar
loasian
I been using Moog K778 screw in ball joints on my control arms, that I built for Toyota.Fits good, just need an extra washer so the nut is in place for the cotter pin.
e10pvmt's avatar
e10pvmt
i assume you are usin drop spindles...and where did you get a sleev for that ball joint to screw into?
can someone get seth to chime in on here...the toyota "god"
e10pvmt's avatar
e10pvmt
so i tried the K778 and it works except it will take a few washers to line up the cotter pin hole...like almost a 1/4 inch or so....this shit is frustrating.....i cant start to build my suspension let alone my frame till i get these damn ball joints
slammedxonair's avatar
slammedxonair
yea i belive they are the same as the MII balljoints moog sells a spacer for them as well.
