Bodydropin My buddys 89 s-10 have a few questions
V
I
ihatetraintracks
I have looked for an answer on ssm and s-10 forum, I can't find anything, we are running into some problems with the clutch arm( sticks out of the firewall below the brake booster) with the b/d it is going to touch the a-arm, what can I do? it's a 2.8L s-10 on 20's. and also when you guys tub the firewall, where is the best place, that you have found to relocate the wiring harness?
sirbodydragger's avatar
sirbodydragger
recess it in the firewall
S10TooDamnLow
The clutch master cylinder on that truck is pretty long, I recessed mine up and into the dashboard, and as far as the wiring harness you can run it through the cowl at the center of the motor.
NorthwestS's avatar
NorthwestS
recess it that is what I did about 1"
mmrcustoms's avatar
mmrcustoms
pics that would be nice
I
ihatetraintracks
Does anyone have any pictures of the clutch master cylinder recessed??? what is all involved, do you just pull the rod out and cut it off a inch, then move everything in? any help would be great
