Chevy/GMC Trucks \  20 by 8.5 on a 87 s-10
views 170
replies 9
junkman   +1y
the wheels i want to use only come in a 10 mm or 35 mm offset. the 10 mm offset will not tuck i think. can i use the 35 mm without spacers or is the offset to much? i don't like to use spacers. thanks for the help.
sirbodydragger   +1y
you should be able to use the +10mm w/ a 1/4in. spacer & MAKE SURE they use E/T lug nuts
junkman   +1y
no one have a s-10 with 20's on it? i need some help guys .
junkman   +1y
thanks sirbodydragger, i was told the +10 would not tuck. this mm thing confuss the hell out of me.
sirbodydragger   +1y
a +20mm offset is ideal for a s10 == direct bolt on so if you run the +10 w/ the 1/4 sapcer you should make up the difference or pretty close, are you buying them from a local shop or online?
junkman   +1y
local shop i'm makin sure i get it right before i order them. are you sure they will tuck. the shop told me +35 with a 1/4 spacer that way they will tuck . sounds right to me what you think????
sirbodydragger   +1y
if its local then they should b able to get one in to test fit, if they dont wanna get one in to test id say they dont want your business, wont hurt to try..... right?
junkman   +1y
i think they don't sell this type of wheel alot so they don't have one in stock . i will see if they have somthing close to it. thanks for the help.
junkman   +1y
bump????????????
NorthwestS   +1y
i have 20X8.5 with a 10mm offset and I had to shorten my control arms about 3/4" to tuck on bodydropped 1st gen s-10
