??????? on backspacing
junkman1jmc@bellsouth.net's avatar
junkman's avatar
junkman
can i run a 20 by 8.5 with +35 mm of backspacing on a 87 s-10 with 235/35/20 tires???????????????????
junkman's avatar
junkman
i ment 225/35/20 .
TravisDTD's avatar
TravisDTD
I show only up to an 8" on the front with a -6 to a +6 offset to keep from rubbing inside and out. Rear can go up to a 9.5 with a -6 offset our guide can be a little conservative but an 8.5 with a 35 is way beyond what we determine will fit.
225.35.20 is a little narrow for an 8.5 they'd be stretched. 235.35.20 on the right wheels will work on all 4 corners.
TravisDTD's avatar
TravisDTD
I am assuming your truck is 2WD.
