help info on layin a caddie
bdydrppup@aol.com's avatar
bdydrppup's avatar
bdydrppup
alright guys im pretty new to cars, so what i need to know is whats required to lay a 69-70 caddie out on fact. 15's. in frame notch, c-notch, drop spindles? havent messed with these cars before, im used to trucks
marcus760
call autocore in phoenix,az.
they are the caddy masters
bdydrp97s10
a small notch will be needed in the rear, as well as you will have to tunnel underneath the rear seat for the driveshaft. no spindles needed
bdydrppup's avatar
bdydrppup
awsome, thanks guys. i just bought a 70 four door deville
doordraggintaco
2 inch cups all around on top of the bag only.lots of trimming and cutting in front.re7 slams work great in front.re6 in rear.
doordraggintaco
oh yea,make sure you plate the trans pan and oil pan with some 1/4 plate,they both will lay with the frame and they really need raised.i found out the hard way when i drug the bottom of my trans pan out.
DraggersDreams's avatar
DraggersDreams
2 1/2 c notch in the frame and cut out for the drive shaft , no need for spindels will lay 20s with just bags and cups
bagged300mondubs
like everyone said, cups on top front and rear, low axle brackets, 2.5" notch, and it will lay on the stock 15's i had to tunnel for the driveshaft all the way to the output shaft on the tranny on mine. also new motor mounts and tranny mounts are a idea to so it lifts them up a little, you can also section the oilpan so it doesnt drag and you lay flat!
